1999 Ford Explorer Tune-up
161,342 MILES • 6 CYL • 4WD • AUTOMATIC
HOPE HUFF
What do I need to do to tune-up my baby, she's burning a lot of gas.
Apr 2, 2008 at 5:33 AM
2CARPRO JACK
  • 11,533 POSTS
Spark plugs and plug wires.Fuel filter and clean the Idle Air Control Motor. Also clean out around the butterfly in the throttle bore with carb cleaner and a rag. There should be a fuel pressure regulator on the fuel rail (where injectors plug in) unhook th evacuum line to see if there is fuel in it, if so replace the regulator, this is probably where your mileage went
Apr 2, 2008 at 9:40 AM
