1999 Ford Explorer Thermostat
126,982 MILES • 4 CYL • 4WD • AUTOMATIC
JIMMY.MCMILLAN
Where is the thermostat located on the engine? It is a 4.0 sohc
Dec 28, 2007 at 8:27 AM
BMRFIXIT
  • 19,053 POSTS
[quote:65c28ef703="jimmy.mcmillan"]Engine problem
1999 Ford Explorer 4 cyl Four Wheel Drive Automatic 126982 miles
Where is the thermostat located on the engine? It is a 4.0 sohc[/quote:65c28ef703]
almost under the throttle body on the intake manifold
above the water pump at the end of the upper radiator hose
Dec 28, 2007 at 8:29 AM
