1999 Ford Explorer temperature gage
190,000 MILES • 4 CYL • AWD • AUTOMATIC
JEFF12580
my temperature gage goes up and down or normal to hot and i can smell like radiator fluid burning of something. can you help with this one? is it my radiator or the temperature sensor?
May 26, 2010 at 8:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if you smell coolant then the gauge is most likely accurate and your vehicle is overheating. check coolant level and see if radiator fan(s) come on properly. if OK remove and test thermostat.
May 26, 2010 at 8:44 AM
