1999 Ford Explorer smell
1999 FORD EXPLORER
99,000 MILES • 6 CYL • 2WD • AUTOMATIC
NAPTIME
I have a 99 explorer that recently developed a horrible smell when the AC was turned on. Now that cold weather has arrived we turned on the heat and the same smell. It smells so bad that it will gag you. We searched for an interior cabin filter thinkinking that maybe a frog or something had gotten in and died. Can you suggest what the smell might be? The smell is only present when the fan motor is turned on.
Nov 11, 2008 at 11:12 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like a faulty heater core. The smell is actually anti-freeze coming through the vents. You may also notice a foggy-film on the windshield.
Nov 11, 2008 at 11:32 AM
