1999 Ford Explorer Slow starting
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
DPH
Car normally starts within 1 or 2 seconds of turning the ignition key. Lately, it has been taking up to 10 seconds, lots of cranking. Had it checked at the local Ford dealership, $100 later no problems identified. They indicated it might be a failing fuel pump, but wanted it overnight to diagnose. Battery is new.
Sep 8, 2009 at 8:02 AM
  • 110,251 POSTS
It could be the fuel pump itself or something called fuelpump drop off which basically means you loose pressure due to a leak, faulty pump, or a leaking fuel injector. As a result, you need to crank the engine until the pressure is regained. What I would like you to do is check for this. Here is a video how to and directions for checking fuel pump pressure and drop off. You will need a gauge to do it. Many parts stores will lend or rent the gauge to you.
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Sep 8, 2009 at 11:51 AM
