1999 Ford Explorer Seat belt alarm?
CHICKENLADY
Computer problem
1999 Ford Explorer V8 All Wheel Drive Automatic
When I start the car, the seat belt safety alarm will sound off 5 "dings" pause and do this 5 times, and if we drive a distance it will sound again, 5 dings, 5 times. Any idea what it is trying to tell us?
Jul 27, 2009 at 5:14 AM
  • 110,246 POSTS
It is trying to tell the driver to fasten his seat belt. If it is, the switch in the reciever must be bad or there is a poor connection in the wiring to the receiver. If you follow the receiver down, you will see wiring for the alarm. Make sure it isn't damaged or disconnected at any point.
Jul 28, 2009 at 4:55 PM
CHICKENLADY
Could it be anything else other than seat belt? When I buckle the belt the light goes off in the dash, but the alarm keeps sounding.
Could it be a code of some sort?
Jul 29, 2009 at 12:22 AM
  • 110,246 POSTS
If the light goes out, the only other thing I would recommend having checked is the body control module (BCM). It requires special test equipment.
Jul 29, 2009 at 4:52 AM
