Engine Performance problem
1999 Ford Explorer 6 cyl Four Wheel Drive Automatic
at times we have a rough idle upon startup after after a few minutes it will smooth out.
the ford dealer did a diagnostic and said we needed
an egr orlng/fuel rail gasket/ing.oring/upper plenum gasket.
what i find odd is if i put a can of seafoam in the gas the vechicle will run fine for a couple of months then act up again.
if we try to drive while it is having a spell it misses and loss of power untill it smooths out.
any suggestions thanks
Sep 8, 2009 at 10:48 PM
