Rear diff g got wATER IN AND MAKES NOISE ON DRIVERS IDE WHEEL
Tuesday, June 1st, 2010 AT 11:00 PM
MECHANIC
Have you serviced the differential to get all the water out? If not, do that. If you have already done it, chances are you have a bad wheel bearing if it is coming from one side.
