1999 Ford Explorer radio lights.
156,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARCELCLOUTIER
I have had this problem since shortly after purchasing this vehicle. The lights for my radio, clock, etc. do not work. It would at one time come on after I had driven a long period, I wondered if it was a problem with the battery that would allow this to work once the car had been for a long drive? Any ideas.
I also have a request for a diagram of how the pieces for the over/drive switch should fit into the end of the stick shift as they got knocked off and i have all the parts but am not sure how to put them back in the end of the shift.
Feb 10, 2009 at 7:23 AM
  • 110,248 POSTS
Hi:
Some of the radios have a bulb that can be replaced, others you have to replace the face plate (not a cheap part). remove the face plate to see if there is a bulb there.
As far as the shifter (od switch) I looked everywhere and can't find a picture for you... sorry
Feb 13, 2009 at 2:27 PM
