1999 Ford Explorer passenger door will not open
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
KIRK2580
hello , my car has power door locks, i can not get the passenger side door to open , i can see the threaded post pop up , but , not enough to pop, i do not want to force the inside handle , can it be the actuator ???
Feb 7, 2010 at 11:41 PM
  • 110,248 POSTS
Chances are the actuator is the problem. But you need to remove the door panel to check to see if the linkage it attached or damaged.
Feb 11, 2010 at 5:41 AM
