1999 Ford Explorer Overdrive warning light
1999 FORD EXPLORER
128,000 MILES • 6 CYL • 4WD • AUTOMATIC
Q MAN
Overdrive O/D warning light on dash is constantly flashing. Car shifts into all gears and overdrive correctly and will downshift when O/D button is pushed on shift lever and back to overdrive when pushed again.
Dec 30, 2008 at 3:38 PM
JGAROFALO
  • CERTIFIED EXPERT
  • 489 POSTS
The O/D warning light is telling you that there is an electrical problem with the transmission. S scan for codes is in order. It is most likely a problem with the converter lockup, since it shifts into all of the gears.
Jan 2, 2009 at 8:21 AM
