1999 Ford Explorer Not getting heat from heater, AC works o
131,000 MILES • 6 CYL • 2WD • AUTOMATIC
HWEBB
I have checked flow of hot engine water thru the heater core with garden hose and flow thru core is fine. Replaced the thermostat. Engine coolant is up to temperature. I think it is the electric blending motor operator in the heater under the dash.
It is difficult to get to as it is behind the glove box and accessble. Is there any simple way to remove the motor without haveing to remove the complete heater & AC air flow control housing under the dash?
Jan 1, 2010 at 10:40 PM
  • 110,248 POSTS
to remove it, everything will need removed. If there was an easier way, I would have een it by now.
Jan 7, 2010 at 4:24 AM
