1999 Ford Explorer Need's help
175,000 MILES • 6 CYL • 4WD • AUTOMATIC
FRDLAMM
Engine is missing realy bad. Random cyclinder misfire, bank i lean, bank 2 lean. Changed M.A.F. cencor, Map cencor, EGR cencor Idler control valve, plugs and wires. I'm getting a code that no one knows 1401. Please help.
Aug 14, 2009 at 7:28 AM
DOCFIXIT
  • 18,828 POSTS
DPF EGR Sensor Circuit High Voltage detected. see figure
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_62.jpg
Aug 14, 2009 at 7:43 AM
FRDLAMM
I have already changed that part and it didnt make any difference. Anymore ideas?
Aug 17, 2009 at 9:06 AM
DOCFIXIT
  • 18,828 POSTS
Have you checked fuel pressure? Did you have code P0300?
Aug 17, 2009 at 9:24 AM
FRDLAMM
I havn't checked the fuel presure. Would it be fuel pump or some kind of sencor? I don't remember any such code.
Aug 18, 2009 at 5:47 AM
DOCFIXIT
  • 18,828 POSTS
Did you check hoses to DPE for leaks, cracking? also possible blockage of ports where hoses connect
Aug 18, 2009 at 5:53 AM
FRDLAMM
Will check. Thank you.
Aug 18, 2009 at 5:55 AM
