1999 Ford Explorer misfiring
120,000 MILES • 6 CYL • 2WD • AUTOMATIC
SKYHIGHMARK
run fine for days and then starts misfiring bad. will stop for awhile then starts again. have replaced coil pack,wires,plugs and cam shaft sensor.
Oct 5, 2010 at 2:15 PM
  • 75,988 POSTS
Engine running rough or misfiring can be cause by the following:
1.Defective spark plug
2.Inadequate spark/coil,defective spark plug wire.
3.Lack of compression
4.False air leakage.
5.Faulty fuel injectors.
6.Insufficient fuel pressure.
7.Contaminated fuel.
8.EGR valve that is leaking.
9.Oxygen sensors.
10.Throttle position sensor.
11.Idle air control valve.
Oct 5, 2010 at 7:02 PM
