1999 Ford Explorer Loud Brakes
NUCLEAR_MELTDOWN
Brakes problem
1999 Ford Explorer 6 cyl Four Wheel Drive Automatic
When I first apply the breaks, there is a metallic grinding noise and then goes away. Also when I was driving some logging roads when hunting and going about 10 mph and using the breaks alot the metallic noise was so lound that I am sure I scared all the deer away. I pulled the tires and inspected the brakes. There is sufficient pad material and the rotors look fine (no scratches or gouges). Any help is greatly appreciated.
Jim Hargrove
Dec 12, 2008 at 10:43 AM
DAVE H
  • 13,383 POSTS
pull the pads out of caliper and recheck .. if there is only 2/3 mil left on pads .. they need replacing ?
Dec 12, 2008 at 12:30 PM
