1999 Ford Explorer knocking
DRDEXPLORER
  • 7 POSTS
Engine Mechanical problem
1999 Ford Explorer Two Wheel Drive Automatic
My explorer ran after running hot it has a knock when idling and driving what could be the problem?
Jul 31, 2010 at 5:25 PM
  • 31,937 POSTS
Hi there,
How hot did it get? have you checked the oil pressure yet? if not i would do this and post the readings, cold idle, hot idle and hot 1500RPM.
mark (mhpautos)
Jul 31, 2010 at 11:54 PM
DRDEXPLORER
  • 7 POSTS
the gauge went all the way to hot and bubbling in resavor oil pressure is good it knocks cold or and at hot tidle 1500rpm oil pressure is midway of the gauge
Aug 1, 2010 at 3:05 AM
  • 31,937 POSTS
Hi there, i will need a P.S.I. reading from a mechanical gauge, i need an accurate actual reading.
mark (mhpautos)
Aug 1, 2010 at 11:46 AM
