1999 Ford Explorer idle and engine light
VALLEYSUNFLOWER
1999 Ford Explorer
my car engine light came on and the engine wont keep idle when started
the engine light code is massive air flow sensor
if i change this will it keep my idle going when i start
Jan 28, 2009 at 12:34 AM
DAVE H
  • 13,383 POSTS
the code is telling you there is a fault with the MAF (mass airflow sensor) .. cleaning/changeing the sensor should rectify the fault ? ..
Jan 28, 2009 at 2:19 AM
VALLEYSUNFLOWER
so what you are saying is clean and the idle will go back to normal
what do i clean it with
Jan 28, 2009 at 2:49 AM
VALLEYSUNFLOWER
so how do i get the engine light to go off or will it go off on its own
Jan 28, 2009 at 2:56 AM
DAVE H
  • 13,383 POSTS
go to a good autoparts store (autozone etc.) ask them for a recomended cleaner .. when you have completed the repair .. go back to autozone etc. ask them to turn the light off for you !!
Jan 28, 2009 at 3:00 AM
VALLEYSUNFLOWER
do you recommend any cleaner or you really dont know
Jan 28, 2009 at 3:03 AM
