1999 Ford Explorer Head Gasket related question?
150,000 MILES • 6 CYL • AWD • MANUAL
KIDDC
I recently had complications with my radiator and few other components in conjunction with the radiator. I lost a few hundred and it would have cost even more apparently. But I declined to get my head gasket repaired. I was told by that shop that my head gasket was blown. I couldn't see any indication of it. No smoke, no sounds, no smells, and no overheating. I can purchase a head gaket part for about two to three hundred dollars for my model. The amount that those people gave me is in the mid thousands but I don't understand how in the world can the labor be that high to be in the mid thousand. If the part ican be nearly inexpensive. I would be grateful if you could tell me whether or not the cost of the repair sounds accurate or whether that shop sounds untrustworthy.
Oct 5, 2009 at 1:52 PM
  • 110,248 POSTS
The parts should be around 200 and labor should be aprox 6 hours X labor rate. A head gasket should not cost in the mid thousands.
Oct 7, 2009 at 12:32 AM
