1999 Ford Explorer Gear Shift Indicator
ED.HERB
Transmission problem
1999 Ford Explorer 6 cyl Four Wheel Drive Automatic
The gear shift indicator is to the right of each number or letter. The transmission works properly in each position and there is no damage undernrath to the cable or transmission. How do I adjust the indicator?
Sep 30, 2010 at 2:26 PM
  • 110,251 POSTS
There is a cable under the steering column cover that moves that when you shift. It will need adjusted.
Oct 1, 2010 at 6:22 AM
