1999 Ford Explorer gas line
1999 FORD EXPLORER
FOCKER
Engine Mechanical problem
1999 Ford Explorer 6 cyl Four Wheel Drive Automatic
leaking gas line on 199 ford explorer. the one going to the gas tank. leaking where you join the gas filter just before that on the hose. want info on changing line how to thanks
Jul 15, 2010 at 1:29 PM
  • 110,240 POSTS
You need to remove the fuel tank to access the fuel line. Check with a dealer to see if you can purchase a direct fit part. Otherwise, you will need to make a new one.
Jul 15, 2010 at 4:59 PM
