1999 Ford Explorer front end noise from wheels
145,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHRISTYNMIKE76
About 1-2 months ago my truck started making a squeaking noise when the wheels are turned while driving! It's got to the point now to where every time I even drive down my dirt road that every lil hole or even slight movement of my steering wheel (or while hitting holes or bumps or even railroad tracks) that annoying loud squeaking happens @ least until I'm driving on a flat surface while keeping my wheels straight....thats the only time it's not squeaking from the front end!! HELP!!! Thanks Alot
Oct 20, 2010 at 10:31 AM
WRENCHTECH
  • 20,760 POSTS
That sounds like the brake pad warning sensor. It was designed to annoy you so you will repair your brakes.
Oct 20, 2010 at 11:56 AM
