1999 Ford Explorer fluctuating guage
126,000 MILES • 6 CYL • 4WD • AUTOMATIC
TACIA
the heating guage started fluctuating from normal to hot, with the check engine light going on when the guage reached hot, but would then go right back down again. i checked under the hood, the reserve for anti-freeze was at the right level, i didn't open the radiator as we just got home so don't have anything to say about it other than it wasn't smoking, but, the hose coming out of the radiator (@ 1/2 in diameter) did have anti-freeze on it.
could there be something wrong with the hose? and if there is, would this cause the ups & downs on the temperature guage?
any help/insights would be great...thanks!
tacia
Apr 6, 2008 at 11:02 AM
MASTERTECHTIM
  • 4,750 POSTS
you Are low on coolant in the radiator and yes replace the hose or whatever is leaking. dont drive until you fix it or you will be sorry.
Apr 6, 2008 at 11:07 AM
