1999 Ford Explorer Engine ticks
115,336 MILES • 6 CYL • 2WD • AUTOMATIC
RICKYSH11
  • 75 POSTS
My 1999 Ford Explorer makes a ticking noise when the truck is running. I used to own a 96 ford taurus which started to make a similar sound before the heads blew. I took my truck to a few shops to get it checked and each place said there was nothing wrong with it. I've been told by the mechanics to use high mileage oil and that would stop the noise from happening. But it still seems to do it. The ticking goes faster as the accelerator is pressed from 0 to about 30 and noise is worse (louder) while idling and usually calms down when driven at speeds higher than 40 mph. I'm not sure what the problem is but all i know is that my previous vehicle was doing the same thing when it had a problem with the radiator. What should I check or do to find out what is wrong or to fix the problem.
Apr 4, 2009 at 8:07 AM
  • 110,248 POSTS
It sounds like you have a lifter making noise. This could be from a lack of oil pressure, normal wear, or a rocker adjustment problem. To check you need to identify what side of the engine the sound comes from and remove that valve cover and check for adjustment.
Also, with regards to the Taurus, make sure all fluids are full and clean.
If you have other questions, let me know.
Apr 8, 2009 at 6:47 AM
