1999 Ford Explorer engine stalls
98,000 MILES • 6 CYL • 2WD • AUTOMATIC
TMARTIN1919
my jeep starts up but stalls while driving and then shuts off but immediately starts back up and shuts off again while driving. fuel pressure is 60psi mew fuel filter,all coil pack firing,mass air flow switching cleaned injectors and has new intake gasket. why does it still stalls and shut off. no diagnostic code at present and all o2 sensors switching
Sep 12, 2010 at 12:47 PM
  • 110,248 POSTS
Are you able to access a scanner to use while driving to see if it picks up on the problem?
Sep 12, 2010 at 2:39 PM
