1999 Ford Explorer Engine Missing periodocially
104,000 MILES • 6 CYL • 2WD • AUTOMATIC
LARRY POPE
Engine misses periodocially regardless of vehicle speed and weather conditions. No starting problem and engine does not stall out.
Mar 17, 2009 at 3:17 PM
  • 75,988 POSTS
Engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Mar 17, 2009 at 3:30 PM
