1999 Ford Explorer engine floods
190,000 MILES • 4 CYL • AWD • AUTOMATIC
BUGGED
I will start it and it will run for a while then it will race then it will flood and die. I hold the gas wide open and it will start then flood again. There are no codes.
Jun 14, 2009 at 6:38 AM
JGAROFALO
  • 489 POSTS
[quote:0d2e49138b="bugged"]Engine Performance problem
1999 Ford Explorer 4 cyl All Wheel Drive Automatic 190000 miles
I will start it and it will run for a while then it will race then it will flood and die. I hold the gas wide open and it will start then flood again. There are no codes.[/quote:0d2e49138b]
Pull the vacuum line from the fuel pressure regulator, and check for fuel. Could also be a leaking injector or a bad intake manifold gasket.
BTW, Explorers did not have 4 cylinder engines. The base engine was the 4.0 V6.
Jun 20, 2009 at 12:16 AM
