You have a few problems. Two of them, the check engine light and ABS light, need to be checked using a scanner. Most parts stores will do it for free.
From the scanner, they will get codes that identify where the problem is coming from. Let me know what they tell you and I can direct you.
As far as the door, does the inside handle feel like it is attached to the linkage?
SPONSORED LINKS
Thursday, July 22nd, 2010 AT 9:38 PM
