Abs light on what is the most common fix if there is one?
Tuesday, December 8th, 2009 AT 9:44 PM
RICKMAR
MECHANIC
I would check or have all 4 ((ABS)) sensors checked.
Usually a brake shop can diagnose the problem pretty fast for low money.
In the sketch below
(1) Hold down bolt. (2) sensor
They are about $22.00 each.
Good Luck;
Rick
SPONSORED LINKS
Tuesday, December 8th, 2009 AT 11:30 PM
PEPPER1950
MEMBER
I will do what you suggested Rick. Thanks for the info.
