Not really a line wrench is needed to prevent damage to flair nuts. Ratchet with extension and deep well socket.
Be sure and bench bleed new m/cyl there should be couple of plactic tubes and instruction in box.After install bleed system rears then front. Protect paint break fluid does a number on paint.
Thanks for donation
Let us know if you need further assistence
Aug 27, 2008 at 6:27 AM
