1999 Ford Explorer Brake Slipage
89,000 MILES • 6 CYL • 4WD • AUTOMATIC
ROCELIK
This problem does not happen all the time. When I
am almost at a complete stop the brake seems to
slip and the pedal gives a little, not completely to the
floor but a enough to make it seem like pressure is
lost. There a no leaks, I have new brake pads, the
rotors are in good shape.
Again it does not happen all the time and when it
does its as I'm almost at a complete stop.
Jun 30, 2009 at 7:05 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Does your Explorer have rear drum or disc brakes? Has system been bleed?
Let me know
Thanks for donate
Jun 30, 2009 at 8:01 AM
ROCELIK
Rear disc brakes, Yes they have been bleed.
Jun 30, 2009 at 10:47 AM
DOCFIXIT
  • 18,828 POSTS
Only thing I can think of is piston seal failure in master cylinder. What happens to pedal if you apply and hold pressure to pedal does it slowely drop?
Jul 1, 2009 at 4:44 AM
ROCELIK
No, The pressure holds, like I said the problem does not happen every time I stop. It happens randomly.
Jul 1, 2009 at 11:28 AM
