1999 Ford Explorer brake sensor
CHUCKISBADASS
Brakes problem
1999 Ford Explorer 6 cyl Two Wheel Drive Automatic
the brake sensor fell off the peddle. & when i attache it . & depress pedal it wont let me put car in gear . it was working before it fell off . is there something im doing wrong? can you bypass that sensor ?? thanks your help is more than welcome thanks ..
May 13, 2010 at 7:23 AM
  • 110,248 POSTS
Are you refering to the brake light switch? Are the brake lights working?
May 17, 2010 at 1:09 AM
