1999 Ford Explorer bog
127,222 MILES • 6 CYL • 4WD • AUTOMATIC
MIKADIN
my truck starts hard and runns boggy unless i floor it it doesnt have the power that it is supposed to i keep blowing my fuse for the cam shaft position sensor and i think that the cam shaft chain is stretched could the chain be my problem
Jan 28, 2009 at 1:53 PM
DAVE H
  • 13,383 POSTS
the camshaft position sensor does not have a fuse ... if the timing chain is loose and the cam has jumped a tooth this could cause running problems !
Jan 28, 2009 at 2:31 PM
