1999 Ford Explorer blinker and hazard
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
MOMNJ
The blinker and the hazard lights are not working on the right side of the vehicle and all bulbs on that side were replaced with new ones.
Dec 12, 2008 at 11:36 PM
DAVE H
  • 13,383 POSTS
You either have a faulty multifunction switch on steering column or there is a break in the white/light blue wire (hot) from multifunction switch to lamps ... it cannot be a ground fault as the front and rear are grounded in different location's .. you could also check/replace the relay
Dec 13, 2008 at 12:03 AM
