1999 Ford Explorer Antifreeze
130,000 MILES • 6 CYL • 4WD • MANUAL
DOVIEMADLOCK
The temperature gauge been below "C" even when the SUV is completely warmed up. I put the 50/50 antifreeze in the clear container marked "engine coolant only", and the gauge still reads cold. Can you tell me what the problem is?
Dec 14, 2009 at 2:51 AM
  • 110,251 POSTS
It sounds like the thermostat is stuck open. I would start by replacing it to see if that takes care of the problem.
Let me know if it helps.
Dec 23, 2009 at 1:34 AM
