1999 Ford Explorer alternator
110,000 MILES • 6 CYL • 2WD • AUTOMATIC
KSOWTI
my battery light came on. I went to mechanic, changed my altenator. car worked fine for 4 weeks. then it stopped. went to mechanic, they said it was a defected alternator, changed it again, everything worked fine for 4 weeks. then again te battery light came on. the charge is low and I think it is about to die again (have a brand new batter)
they now tell me that the alternator is OK.
what else can it be that the battery is not charging?
what should I do?
Dec 23, 2007 at 12:08 PM
BMRFIXIT
  • 19,053 POSTS
[quote:26d8fafe02="ksowti"]Engine problem
1999 Ford Explorer 6 cyl Two Wheel Drive Automatic 110000 miles
what should I do?[/quote:26d8fafe02]
check the small one plug wire on the alternator
check fuses
check the 3 wire plug also
and if all good let them get you diff brand alternator
Dec 23, 2007 at 1:46 PM
