1999 Ford Explorer 4 wheel drive module
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
GARY G. DEAN
My 4 wheel drive high and low light flashs on and off 6 times and then stops for a while and then does it again. When I try to ingage the 4 wheel drive switch I have no 4 wheel drive. I have been told this is the module, and it is located behind the glove box. Any one know how to get at this part and how to remove it?
Oct 19, 2009 at 11:00 AM
DOCFIXIT
  • 18,828 POSTS
Hi Best action is have trans scanned to diagnosis fault with a scan tool as in pic.
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_192.jpg
When you get results post and will advise. The GEM is located behind radiod console. Hope this helps Thnaks for donate
Oct 21, 2009 at 1:52 AM
