1999 Ford Explorer Will Not Idle Without Pressing Gas
TAZ1012
Engine Mechanical problem
1999 Ford Explorer 6 cyl Two Wheel Drive Automatic
i have a 1999 ford explorer that wont stay running unless i keep my foot on the gas. i have replaced the fuel pump the fuel relay and the fuel filter. what is wrong with my car
Oct 16, 2010 at 3:05 AM
  • 110,248 POSTS
Check for vacuum leaks. If none are found, remove the idle air control motor on the throttle body and make sure it is clean and the valve is moving. If it is stuck, replace it.
Let me know what you find.
Oct 16, 2010 at 3:23 PM
