HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Explorer
Trouble Codes
P Codes (Powertrain)
P0700 - P0799
P0734
1999 Ford Explorer
GRAMPAMONT
MEMBER
1999 FORD EXPLORER
6 CYL
AWD
AUTOMATIC
102,776 MILES
A co-worker of mine put his scanner on my vehicle
got codes PO734 andPO735. Gear 4 and 5 incorrect
ratio. Does this mean I have a bad sensor?
My explorer has been running okay until two nights ago.
Thank you for any help you can give me.
Thursday, January 17th, 2008 AT 5:42 PM
BMRFIXIT
MECHANIC
Its most likely going to need to be rebuilt
its an indication that the tranny is slipping
Thursday, January 17th, 2008 AT 6:11 PM
Please
login
or
register
to post a reply.
Related P0734 Content
2003 Ford Explorer Code P0775
When Starting Off I Have To Take My Foot Off Gas So It Will Shift From First To Second, The Other Gears Shift Fine Except For The Overdrive...
Asked by
Tonya Scheeringa
1 ANSWER
3 IMAGES
2003
FORD EXPLORER
Codes Are P0420, P0761 And P0402
I Got My Codes Just Read It Came Up With Three Code Can Anyone Give Me The Cheapest Way To Fix These Codes They Are P0420 And P0761 And...
Asked by
derrickcom
1996
FORD EXPLORER
2003 Ford Explorer Fix P0735 Solenoid
Where Do I Locate The Solenoid B That Affects 5th Gear And How Is It Fixed?
Asked by
tejaslady
1 ANSWER
2003
FORD EXPLORER
2002 Ford Explorer Odb Code P0735
What Canit (should It ) Cost To Repair A Obd Code P0735?
Asked by
mbellas
2002
FORD EXPLORER
Code P0775
Today While Driving My 2003 Ford Explorer, The O/d Off Light Began Blinking Although There Did Not Seem To Be Any Other Issues. I Stopped...
Asked by
talbotsr
1 ANSWER
2003
FORD EXPLORER
VIEW MORE
Code Read Retrieval/Clear Mercedes-Benz C230
How to Read Codes
What to Do When a Check Engine Light?
