2003 Ford Explorer fix P0735 solenoid
2003 FORD EXPLORER
121,000 MILES • 6 CYL • 4WD • AUTOMATIC
TEJASLADY
Where do I locate the solenoid b that affects 5th gear and how is it fixed?
May 15, 2009 at 7:22 AM
2CARPRO JACK
  • 11,533 POSTS
That code can be caused by other issues besides simple solenoid malfunction.Internal issues such as damaged friction materials, stuck valves or the engine rpm being higher or lower than expexted for that operation range.This is one that i woudl suggest taking to a trans shop to have troubleshot.They have the scanning equipment to command certain gears on while measuring voltage/resistance across other solenoids to be sure that the root cause is actaully the 5th gear solenoid and not other internal issues.
May 17, 2009 at 4:46 AM
