1999 Ford Explorer
EXPLORERGREENBEAST
  • 1999 FORD EXPLORER
  • 6 CYL
  • 100,010 MILES
When im driving there is a noise from the right front passenger wheel it doesnt get noticed bad unless im driving on the interstate a friend told me it could be bearings need to be replaced I recently had the tire replaced wouldnt the guy notice it when balancing
Saturday, June 27th, 2009 AT 9:57 PM
BMRFIXIT
  • 19,053 POSTS
Turn off air suspension switch (if equipped).
Switch is located behind right rear quarter panel. Raise and support front of vehicle.
Remove wheels.
Reinstall 3 lug nuts to secure rotor to hub. Check hub nut for correct torque. Using a dial indicator, measure axial end play at hub. Maximum axial end play is.003" (.08 mm). If reading exceeds specification, replace wheel bearing assembly
Sunday, June 28th, 2009 AT 10:30 AM
