well basically all i know is it wont start when cold. its got the 4.0 sohc which is basically a pain to diagnose. i can get it to start but i have to take the wiring harness loose from the pcm and hook a voltage tester to the hot battery terminal and test every little hole on the wiring harness and then when i hook it back up it starts. any ideas of whats causing this.
Dec 10, 2009 at 9:54 PM
