1998 Ford Explorer won't start
70,000 MILES • 6 CYL • 4WD • AUTOMATIC
TTHOMAS53
Second time in two months the engine will not start. Wait a few minutes then it starts. Could this be the fuel pump going out or maybe fuel pump relay? If so where are these parts located? In the gas tank?
Jun 11, 2010 at 2:21 AM
  • 75,988 POSTS
Lets do below for a start to determine if its fuel or spark related issue and get back with some results
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Jun 11, 2010 at 2:42 PM
