1998 Ford Explorer windshield wipers, windows, interior lig
190,000 MILES • 6 CYL • 4WD • AUTOMATIC
OEBB1
I own a 98 Ford Explorer Sport. The windows, interior lights, windshield wipers and the rear defrost work sometimes but at other times they dont. They all come and go at the same time. What could possibly cause this?
Jul 29, 2009 at 11:56 AM
BUDDYCRAIGG
  • 2,262 POSTS
the only common item in the electrical circuit is the ignition switch,
but that doesn't explain the interior lights.
are there any other items that stop working?
Jul 29, 2009 at 12:10 PM
OEBB1
I believe the 4 wheel drive goes out too.
Jul 29, 2009 at 12:49 PM
BUDDYCRAIGG
  • 2,262 POSTS
that's in the switch too.
when you said interior lights, what lights are you talking about.
Jul 29, 2009 at 1:38 PM
OEBB1
[quote:c445f0da9e="buddycraigg"]that's in the switch too.
when you said interior lights, what lights are you talking about.[/quote:c445f0da9e] the ones on the headliner. when you say ignition switch, do you mean where you put the key in?
Jul 30, 2009 at 1:03 AM
BUDDYCRAIGG
  • 2,262 POSTS
[quote:8f0210f5a6="oebb1"]the ones on the headliner. [/quote:8f0210f5a6]
Now that part doesn't make any sense. Those are normally turned on and off by some sort of body control module.
[quote:8f0210f5a6="oebb1"]when you say ignition switch, do you mean where you put the key in?[/quote:8f0210f5a6]No, the place you put the key is only the mechanical lock, I'm talking about the electrical switch that the lock is connected to.
Jul 30, 2009 at 2:33 AM
OEBB1
No, the place you put the key is only the mechanical lock, I'm talking about the electrical switch that the lock is connected to.[/quote] Does replacing this swiitch require any special tools or equipment? Should I have a pro do this job?
Jul 30, 2009 at 10:49 AM
BUDDYCRAIGG
  • 2,262 POSTS
[quote:2f608d69ab="oebb1"] Does replacing this swiitch require any special tools or equipment? Should I have a pro do this job?[/quote:2f608d69ab]
It's pretty simple to do with normal hand tools.
The good news is they are cheap.
The bad news is you need to be a contortionist to be able to get to them.
it's mounted on the steering column, kinda above your knees.
Jul 30, 2009 at 11:36 AM
