1998 Ford Explorer Transmittion Problem?
110,000 MILES • 6 CYL • 4WD • AUTOMATIC
RANDOKEE
When I pull up on a hill and put the car into park it will roll back a few feet. In addition, I hear a series of clicks like a gear is slipping. Is this a major transmission problem or would it be easy to fix? Bottom line: should i trade the car in while it has some value or can the car function as is or with little repair?
Oct 12, 2009 at 10:43 AM
MIKELEE1011
you might need to adjust you linkage on your gear shifter. i had that problem and i tryed it and it fixed the problem
Oct 16, 2009 at 6:12 PM
