1998 Ford Explorer transfer case
232,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARUNA
vibration,rear output shaft has about 1/8'' to 3/16''
up and down play,seal is leaking.is it a bearing ?
If so , how hard to replace.
have years of all kinds of mechanical exp.
Just not familair with this t-case.
steve
Feb 5, 2010 at 2:03 PM
  • 110,248 POSTS
THere is a bearing and a retaining clip that is most likely the problem. You need to remove the tail shaft to access the bearing.
Feb 11, 2010 at 7:49 AM
