1998 Ford Explorer Timing Belt
232,436 MILES • 4 CYL • 2WD • AUTOMATIC
CRIDER24
My car is making a rattling noise once turn on and driven and my question is does my car has a timing Belt 98 Ford Explorer and what would it be that is making that noise
Mar 6, 2010 at 6:43 AM
  • 110,251 POSTS
Your engine has a timing chain. If it is really loose it could make noise. However, can you tell aprox where the noise is coming from?
Mar 8, 2010 at 3:32 PM
CRIDER24
[quote:0d489b9601="Jacobandnickolas"]Your engine has a timing chain. If it is really loose it could make noise. However, can you tell aprox where the noise is coming from?[/quote:0d489b9601]
the noise is coming close to the top where my thermostat housing /engine is not in the bottom
Mar 9, 2010 at 5:56 AM
