Engine Cooling problem
1998 Ford Explorer 4 cyl Two Wheel Drive Automatic 287k miles
Can I run without a thermostat in the summer?
Tuesday, August 12th, 2008 AT 4:57 PM
MERLIN2021
MECHANIC
If you don't mind burning some estra gas at times! The engine has an engine coolant temperature sensorn and if the engine runs too cool, the PCM may increase the mixture to the rich side to compensate.
