1998 Ford Explorer Thermostadt
114,000 MILES • 6 CYL • 4WD • AUTOMATIC
MERRIK
I need to change my thermostadt and am looking for an online engine "map" if you will. Any ideas or can you tell me where in the engine I could locate it as I've never done my own repairs to this vehicle. It seems like it should be a quick process and then not necessary to take into, or pay for, a shop to do it. Thanks so much.
Merri
Jan 27, 2008 at 8:00 AM
XPRESS
[quote:c30c72b8c8="merrik"]Engine problem
1998 Ford Explorer 6 cyl Four Wheel Drive Automatic 114000 miles
Merri[/quote:c30c72b8c8]
Merri. Follow the top radiator hose to the engine. Where it connects to intake is where you can find the thermostat. You can remove the top raditor hose and thermostat housing and replace thermostat and reassemble. Be sure to top off you antifreeze mixture as you will lose some antifreeze when you open the system
Jan 27, 2008 at 8:06 AM
