Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Explorer
Climate Control
Blower Fan
Not Working
1998 Ford Explorer the heater motor doesnt work
1998 FORD EXPLORER
200,000 MILES • 6 CYL • 4WD • AUTOMATIC
TECHNOCAM88
MEMBER
1 POST
ive tested the relays, the fuses and they all work but the blower motor still doesnt run
Jan 18, 2010 at 7:47 AM
Experienced Mechanic
Are you getting power to the motor? Have you tried running a jumper wire direct from the battery to see if it runs?
Let me know. Also, make sure it has a good ground.
Jan 21, 2010 at 2:46 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
