1998 Ford Explorer starting
198,000 MILES • 6 CYL • 4WD • AUTOMATIC
GLOM11B
I just bought this car and had it about a week. it is getting cold here. one morning it just wouldn't start. all the lights still work fine and i tried jumping it but all it does when i turn the key is click once. i think it is a fuze or the starter. any thoughts?
Dec 12, 2009 at 10:30 PM
MATHIASO
  • 1,209 POSTS
It seem like the starter solenoid does not pull-in and starter does not crank (audible click is heard. Check for open fuse, low battery, inoperative fender apron relay, open circuit or high resistance in external feed circuit to starter solenoid. I think the most likely is an inoperative starter. Before replacing the starter, check the fuse. if fuse is good, go through the starter evaluation procedure (voltage to starter)follow before any replacement. sending the procedure to your email too. thank you for using 2carpros.com
https://images.2carpros.com/forum/automotive_pictures/46384_0996b43f8021b7da_1.jpg
Dec 12, 2009 at 11:43 PM
